i may have gone crazy but im sure we used to be able to edit all of our posts, now it seems i can only change the last 1 i made.
this means im accountable for all i say :) i cant handle that kind of responsibility you know how much crap i talk and how often i offend people and need to change my statements to appear like im a decent human being to anyone that hasnt read them yet :(
is that how it is for everyone now?
was just gonna change my cruise thread to done with pics
Edited by gzilla
ha, ha, too late Dan, you're stuffed now..........just go and swallow a bottle of sleeping pills :)
hahahaha all the more reason to donate once you donate you can even delete your own posts if you think they were that silly :P
>>How to Donate<<
this means im accountable for all i say :down: i cant handle that kind of responsibility you know how much crap i talk and how often i offend people and need to change my statements to appear like im a decent human being to anyone that hasnt read them yet :D
nah, we start at 6am, however we haven't got much on at the moment and with a little bit of persuasion we convinced our boss we weren't needed today. :D
And even then it wasnt much pursuasion LOL..... You heard if we're working tomorrow?
f**k I was bored today.
GET ME A JOB THERE :down:
im so over my boss was meant to do overtime today then he cancels on me because i forgot to put an ingredient in a batch then had to put it in and re-blend then colour didn't come out quiet right, AND then the guy that's been there 15 years couldn't figure out what to put in to fix it and i had to do most the guess work :D
tell me that's worth $16 an hour
hahahaha all the more reason to donate once you donate you can even delete your own posts if you think they were that silly :down:
>>How to Donate<<
Thanks Madaz, was wondering how to donate. I was going to ask... Honest... Considering skylinesaustralia has given me so much, i thought i might give alittle back :D
were u home this arvo?
the keto wasnt there (puddle of oil was tho LOL) but i still knocked on the door..........mandy seemed to kno i was there tho :(
the keto wasnt there (puddle of oil was tho LOL) but i still knocked on the door..........mandy seemed to kno i was there tho :)
What time was this? Picked Dom up from work @ 3, then did some shopping, was home by 4 ish I think.
Dave is right though, should have called me LOL. Ill only not pick it up if I dont want to talk to you :):D
Puddle of oil is from the stupid 4K inverted oil filter dumping it's guts like it had a hot curry LOL. Did an oil change yesterday. Ill grab some H/D Degreaser... no - one will ever know. :(
GET ME A JOB THERE :blush:
im so over my boss was meant to do overtime today then he cancels on me because i forgot to put an ingredient in a batch then had to put it in and re-blend then colour didn't come out quiet right, AND then the guy that's been there 15 years couldn't figure out what to put in to fix it and i had to do most the guess work :whistling:
You only get 16 dollars an hour????? thats crazy.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
