Just a random question - anyone heading to the show this year? or we all agree, as always, that its a waste of money lol
Its robbery!
I'm going anyway, as Tracy's son is eager to go. Remortgaging the house so we can go. :P
Ted - "as always" implies that usually when i speak to people about the show they say its a waste of time. That was not directed at SAU in general lol. Because yes you are correct, i was not on SAU this time last year. Well done. Have a cookie.
run around the house making pshhhhh noises, and side step around corners :)
like this :P
name="allowFullScreen" value="true"></param><embed src="<A href="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
