REGENCY for me tomorrow, im bloody stressing whether ive done everything and havnt left anything out, my car is completly stock as it just came off the production line, evn put the side mount intercooler back inn :)
Good luck mate, hope it all goes well :)
hey smart computer people, got another problem with my new laptop.
I have vista, something im still working out, but how do i make it automatically remember my usernames, past searches in google etc? So i dont have to keep retyping them every time
Upgrade to XP :)
Do you have cookies enabled?
thanks guys, im booked in at 1.20pm, cant wait 2 get it back 2 how it was and hopefully in time for the Graham West dyno day
you got a late friday booking, you might get lucky mate! they seem slack on the end of the week :)
upgrade to an older, more familiar experience.
goddam vista is shocking.
U said it brother
Man, I've been doing support from 1st to 4th level over the last 10 years and I've never been as frustrated as when I have to do something inane on vista, like diagnose why a pc cant browse. lets see
theyre connecting ok to the wan
they have gateway, dns, ip
they can ping stuff on the net
but because micro$haft decided to put in some dicked out "feature" where if they cant ping their own servers, they will assume your PC is offline and >REFUSE< all routing requests..
does my head in why they would have to add something as mentally retarded as that
smegheads
-D
out of 12 or 13 times ive been ive only failed once and that was when i was going through with the skyline after i got it imported for its first inspection.
i had 6 holes in the stock exhaust and fecked bushings :) something i should have checked but my parents took it through for me while i was away.
its VERY easy to pass first shot, just have to know what to look for :)
just after a bit of advise from those in the know. just taking off old turbos to replace with new.. drained oil and water... and then going to replace.. will start and idle to let new fluids circulate through turbos... anything else i need to know?? will my car run just to get it to the mechanics(for a tune) if i keep it under 3 grand?? please pm me if there are any major obsticles.. thanks in advance
cheers and may the force be with you
make should you don't start it only crank it, quickest way to ruin brand new turbos
craig, you free tomorrow?
ill let you know if i can change that gasket or not, if not sat maybe
bring the map sensor and i can meet you there as Craig isnt far from me, i can figure out the installation bit :(
REGENCY for me tomorrow, im bloody stressing whether ive done everything and havnt left anything out, my car is completly stock as it just came off the production line, evn put the side mount intercooler back inn ;)
+1 good luck man but im sure you wont need it
steve you have to be the most efficient poster in SAU.
dont get my wrong u still whore it up...
but damn it you do it with so much class, can answer 11ty questions in a single post, then take off to do the same in another topic
/tips hat
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
