lol ryan,do we wanna know how you know how to do that :) lol
eddy, ryan pretty much knows everything about everything most times so more than likely he will be able to figure it out. Hopefully its something small.
haha lol, i had to bypass mine when my alarm shit itself :D
and thanks for the kind words :thumbsup:
Are you saying no electrics work?
An immobiliser may effect your central locking (but i wouldn't have thought so) but if you have no other electrics in the car I doubt its the immobiliser and certainly not the starter motor.
Can you get your alarm to activate? interior light or headlights to work? hazard warning lights? (an immobiliser shouldn't stop all of these from working and will indicate the problem is instead between the battery and the fuse box)
You said you checked out the battery - but it might be worth trying another one if you have one handy, or try a jump-start.
I would also be checking the battery terminals (you wouldn't be the first to have corrosion in the terminal cause a problem like this)
Not sure if the 32 has a fuse in the main battery line (some cars do) or a big spade fitting that has corroded (took me a while to find this problem on an old valiant once)
Yeah, none of the electronics work. None of the lights (interior, headlights, etc). I'll try the battery out of one of my parents cars today but it shouldn't be that as it's only a few weeks old and it's been working fine since I put it in.
anyone got a spare rb26 injector????? one of mine looks like the seal is on the way out......i plan to go upgraded injectors down the line, just wana get a stokie one in there for now untill i can afford to do a bunch of mods at once
OUCH!
quick question for people, anyone know what the legalities are on people parking directly opposite your driveway? I knudged into the neighbours car across the road this morning but they were parked directly opposite my driveway. As far as i was aware it was illegal to park opposite a driveway? So i wanna know if im entirely at fault or if he is partly to blame too?
Cheers.
i know ur not meant to park closer than 1.4 or 1.7 meters from a driveway (on the same side of the road)
far as i know common sense should prevail when u park your car across the road from a drivewya, sounds like your neighbor may be a few sandwiches short of a picnic
Anyone know where to find a bosch 040 for cheap?
yeah i possibly know of a place will PM you later
OUCH!
Cheers.
i always thought it was and or should be against the law but mum says no its ok
eddy, Performance Auto Electrical are also very good. Have done a couple of small jobs on my car. He comes into my work abit and does some jobs for us too.
So just went to try and speak to the people across the road about the accident, the have gone out so left it with the babysitter to tell them to come talk to me. Spoke to plice, they say there is no law against car parking there so looks like im up for a repair bill :S
Well im back for the first time in a few days, had an awesome 21st, was feeling a bit sick at my party unfortunately and didnt get hammered, but i guess im glad i enjoyed the night. Just finished putting together my Blitz R34 D1 drift RC car :blink: Gotta go buy some more paint tomorrow to finish off the shell.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
