R33 tank is 65Lt its my understanding that once the fuel light comes on there is 15lt left in the bottom of the tank it may be 8lt i cant remember, i know i read it in my manual though
Very nice. That means I had 14L left and did 478KM including some spiritedly driving! Thats pretty damn good economy :D I was freaking out thinking the cars going to conk out somewhere in the hills haha
so, in perth at the moment. went to the air race today, was fairly awesome aside from the long amounts of nothing in between shit. and goddamn perth has some pretty harsh sun, im pretty burnt up, lol.
^ so you did decide to piss off for a bit with that car money Dave. I got booted from the cas :D
got my new rims...
lenso D1R...
18x10+22 and 18x9 +15
hmmm lets say anyone keen for some mexican?
They doon't look too bad fitment wise. Is that with the suspension compressed? Even if it is, you could probaby get away with some nice tyre stretch and a bit of camber. If the suspension is hanging in those pics, I dare say the camber from loading it up + a stretched tyre will have those fitting fking brilliantly.
Either way a guard roll will be needed though :)
Haha thanks guys.
Nah he didn't wash it down with a Paley - but he is always trying to get his lips around a beer. Like father, like son I suppose.
Let me tell you though - after he finally came down from his sugar high he slept like a log last night :D
went on the Nissan Silvia Just Drive cruise, and had this happened to my mate (i was the passenger)...
As I was leaving the car park I was following the black 34 who decided to chuck a massive skid, cuttin a blind corner on fifteenth st, then he snapped it back sidewayz around the corner, spun out and was millimeters from hittin a stoby pole. Then he pulled another massive skid and drove off so i followed him thinking that he was goin on the cruise. After 3 minutes or so of following the dude i realised that he wasnt goin on the cruise. At this point i was lost, so i pulled over to have a look at the map and i realised that we were goin in the opposite direction to everyone else. So i turned around and tried to find my way back and got lost again. I cant bloody believe it! I was so frustrated that I ended up goin home.
just wondering who this hero is as he had an SAU sticker...
you know its ppl like that thats giving the rest of us a bad name...
THIS IS EXTREME!
FULLY BODY TATTOO
You thing you're tough and can handle tattooing? :)
Scroll down if you're not squeamish!
:):D:(
Edited by RubyRS4
hey guys just need to vent a little
my boyfriend Dante of 2 weeks went away for "work" without telling me he was going, and then i find out that while we were together he took some chick out off face book to lunch then after 3 days of not talking to me cause of "bad reception" he sends me a sms breaking up with me because lachlan is a big problem. when i got home yesterday there was a really nice email saying i need to get super model looks and loose weight so i can wear the bikini he has picked out for me and clames we were still together, so this is what i find today on his face book
Christie Hales-Thornton wrote at 7:12pmHey Sexy Boy, big THANK-YOU for the lovely lunch in Naracoorte. I'm in Adelaide next week, can't wait to catch up for coffee.
XOXO
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
