[quote name='HVN 032' date='3 Jan 2009, 01:58 PM' post=' member is looking at doing the same for a chaser! Jeez chad took ya long enough....... only joking nice work
Hey, its only taken me about 6 months :(
can anyone recommend anygood places to get roll cages made up that are road legal, cauz i wanna get a drift car biult up, and still have it legal for the road.
cheers... michael p.s guess its gunna be an expensive sport but, seems like poeple are getting into it, oww luke(orgzmc) do you know much places to get good parts and what i need for it, im thinking of a 180 or such.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
