Half cage is legal. I'll get the section from the ADR handbook in a sec.
From memory, it must be padded and you must re-register your car as a 2 seater, but I'll look it up now.
Edit: and get it engineered, and carry the paperwork with you. But either way, cops wont have a clue and will defect you even if you show the engineers report.
Edited by CRoNic...
can anyone recommend anygood places to get roll cages made up that are road legal, cauz i wanna get a drift car biult up, and still have it legal for the road.
cheers... michael p.s guess its gunna be an expensive sport but, seems like poeple are getting into it, oww luke(orgzmc) do you know much places to get good parts and what i need for it, im thinking of a 180 or such.
Alright here's a quote from what the act says:
Roll Cages
Due to the increased risk of occupant injury in vehicle accidents the fitting of full roll cages are not permitted.
However, the fitting of a roll cage rearward of the driver is permissible providing that:
a. No part of the roll cage is contactable by vehicle occupants when positioned in their normal seating
position.
b. The roll cage is at least 150 millimetres rearward of the front seat occupants when the front seats are
located in the most rearward adjusted position.
c. All rear seats and seat belt assemblies fitted in the rear compartment are removed.
d. The operation and effectiveness of the front seat belt assemblies is not affected in any way by the roll
cage.
e. That no person travels in the rear of the vehicle at any time.
-dstroy u plan when and when you not gonna need it :D i think i might go roll my car
on a unrelated matter the 1 benefit of police attention on cars is i can skate freely where eva the hell i want, gone are the days i used to get 30 min leatures of pointless dribble and friends getting $50 fines. was skating down jetty rd went past a cop with time on his hands and nope didnt even so much as look at me. love it ;)
here is my stealth ute shes a monster now with the black sunnies and truck pipes, wonder how long till the cops pull me over bout it. :P
keep a look out for this at glandambo 4x4 event if anyone here goes to it you might see me there this year. im gunna jump the table top and land in the mudpit, hopefully land on all fours.
on another note is it illegal to have your cam gear cover off as i want to get some purdy red cam gears.
Not sure if it's illegal but I wouldn't recommend running no cover, if a stone gets kicked up from the road and comes into contact with the timing belt and causes trouble, things could get interesting. Just buy a clear cam cover then you have protection and can still see all the pretty stuff
hey all, just wondering if anyone knew if you can put gtr injectors into a 33 gtst and if so what els do u need? eg resistor packs
i do believe its a no go... they only fit on rb30 an 20 from wot i'm told...
rb25det are side fed, rb25det neo is top fed and rb26, rb20 are top fed
it could be done but there needs to be some modifications to the rail, collars etc best bet is to just go with side fed sards or nismo injectors
http://www.news.com.au/adelaidenow/story/0...5018092,00.html
For everyone who hates the human colostomy bag known as Amber Petty.
-D
Cruel but funny: 9% (60 votes)
Tall poppy put-down: 7% (50 votes)
Hurtful and uncalled for: 10% (65 votes)
Total rubbish: 14% (93 votes)
Spot on: 58% (372 votes)
HAHAHAHAHAH
Edited by AndrewJZX100
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
