this little runt called like 5 times saying ''i won free adidas shorts'' and shit like that, as soon as i started paying him out,
he giglled like a little school girl!!
and then i said optus was tracing his number and he hung up strait away.....
so.........th reverse phone book is???
shame about the defect scott, least you got a few days to drive it around. girl i work with was defected by our friendly officer neil in her 180 not too long ago.
also, i love finding random shit for the s14 on yahoo and import monster, i see you lurking ben, you know you want it. :P
woot
1st warning
lol you landlubbers you, not appreciating my "neil"-love (in a pure manly way of course)
muahahahaha !
fk it. karma is a bitch I say. always has been & always will be.
we'll see....we'll see.
That's cool as f**k. I was either going to do either leopard print or Luis Vuitton Door trims/shifter boot/cage padding/cam covers.... but thats awesome.
Got better things to spend $350 bucks on ATM though... Like camber arms... :P
I played around with my Coilovers tonight.... I cant go any lower without smashing the kit to pieces on ripple strips... Just how I like it. 25mm spacers and rear camber arms by this weekend.
lookin good ben, huge improvement with the stickers gone, lv print everything sounds like a laugh.
hmm, 2000 posts and i didnt even notice...
Edited by scandyflick
Well since its my 21st :P tomorrow i think SA SAU should donate to me a:
Fully built RB26/30
Twin GTRS's
Full Bride interior
East bear rear bar/sides/ z-tune front
think that isnt to much.
Much love Luke ;)
Edited by Luke_ENR34
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
