if it involves a pm it mustve been a fair whack.
got a clutch, now i need it fitted, recommendations/prices?
my mate shannon got his fitted by a local guy to me with a hoist in his shed, and there is also Just Jap @ jacobsen cress. they do excelent work great rates and i just had my water line replaced from the turbo with them :) from me
Thats cos you dont have a front diff sitting right under your oil filter, and you have skinny little arms :)
it would mostly be hard due to your fuel rail and plenum being right over the top
this is the cooler/relocation kit that i got (not using the relo kit cos i already have one).
HKS rip off, speedflow lines
$239
Question:
Braided lines are considered defectable by the police right? So what happens if you get Pirtek to do the lines. I'm sure their standards exceed AS and therefore meet ADRs if used on motor vehicles?
Reuben, I passed Regency with my oil cooler installed with Speedflow lines and Earls fittings... they didn't have a problem so long as it's mounted correctly and the lines aren't tracing all over the engine bay (ie. nice and tidy)
I'm sure Pirtek would do the lines also :)
My turbo oil line is braided from Pirtek. The water line is stock.
My auto oil cooler line is braided from Davies Craig.
My brake lines are braided from Maltech.
^^ this work exceeds stock standards so I cant see how its possible to be classed ultimately as illegal modifications
thats the thing, Ive got a massive list of mods but could only count a couple that need to be engineered. doing that atm, pretty much.
nothing wrong with getting other braided line made up by Pirtek, the only one that they can't do are the brake lines and i'm pretty sure that if you ask them they will refuse to do it anyway. If you get another place to make up brake lines and they don't put the ADR sticker on them then they are illegal and you will fail an inspection.
Here's my oil feed line the Pirtek made up;
Hence why (as radical as it is) my bike is completely ADR approved.
As much as I've been tempted to remove certain stickers for show purposes (see below), I haven't or else they are no longer approved brake lines.........they could then be anything!
Don't suppose anyone's got banjo bolts for the front R33 calipers lying around, or know where I can get them (most wreckers prob won't part with them)?
Wanna fit the 4 pot calipers and ditch the 2 pot ones.
:D
try Steve at Nisswreck or Pete Hall at Jap Motorsport Roo
Thanks Pete. Was going to drop in to Nisswreck on Saturday if I have no luck with the brake mob on The Parade today. While I'm out there, I'll swing past JMS. Going to lunch shortly to do all that. :D
so ive found out that my engine in my car is from an R32 GTR V-Spec and was purchased from Autotech of all places , and had 80,000kms on it at time of being swapped into my car which in actual fact means its done over 100,000kms , never been serviced and had the speedo in the half cut wound back.
lol. yeah i heard about it around then LOL gotta love corporate email... im glad that news of important things sweeps adelaide quickly
As someone who moved here from interstate, it constantly surprises me how tiny Adelaide is - especially with stuff like this. You find out that your neighbour knows a guy you work with, or that some guy you met on the internet knows a friend of yours, or ... the list goes on .. It boggles the mind :P
Nene has some serious real estate. :P
A project I'm working on at the moment, and I found this:
"Nene Valley". Not far from "Blackfellows Caves"! :P
Ah ... back to work.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
