anyone here need there guards rolled? Getting my hand on a guard roller next week to roll chad's and possibly my car. If i do a good job on my car, would anyone been keen to get there guards rolled?
Hey ppl, I haven't been on here in ages... Pretty much my Skyline has been in and out of morpowa with cooling and suspected coil issues.
Making me broke in other words. Cooling is all fixed but ever now and then it will drop the first cyl making it run on 5. Diognostic said something to do with ignition something... Has anyone had this problem?
Morpowa are looking more into it
. So... Anyone had this before?
Thanks SAU ;)
Would that make it do it all the time or now and then? Engine light comes on too...
They seem to think it could be from water and coolant getting in the coil...
It's a big job just to get to them on a non turbo.
if water or coolent is getting in there check for a split hose around the top of the motor. I found one in mine i had to replace it..
I had to take mine out roughly 3 times as i tryed new spark plugs and they didnt work, then i tried wrapping the coils in tape and that didnt work, then i put the splitfires in and that worked. Only takes me roughly 10mins to change the plugs/coils now.
Engine light might mean a loose connection somewhere, or could be the coils. Bad coils will make the car chug every now and then but sometime seem fine.
Engine light comes on whilst still running?
Misfiring really comes down to a few basics. It's either the spark plug itself, the coil, ignition amp, ECU issues, or any of the wiring and connections between the listed components. It's just a matter of working through each item and removing it from the equation until you pin point the problem.
I would start with identify which cylinder it's dropping and then go from there. If the plugs are all fresh and aren't being continually re-fouled then look at swapping the coil over from the cylinder that is dropping out and see if the problem follows - it might take a bit of time if the problem is intermittent (intermittent problems are a PITA).
Make sure you also clean the coils and the area in between the rocker covers and ensure they are all free from moisture. If moisture (from coolant or any other source) keeps appearing after you've cleaned it thoroughly then something is certainly amiss and it's not a coil problem!
I've got 6 factory RB25DET coils in perfect health sitting in my shed that can be used for testing purposes - unfortunately they probably won't help on a R34 RB25DE.
Good luck.
Good luck.
Yeah engine light comes on while it's running like that then goes off when it's back on 6.
The coolant issue was sorted with the new cooling system so I know how it could have got wet.
Morpowa said it's a big job to get to them? Taking off water lines and stuff... Like a 2 hour job.
I think it may be coils as luke said cos that's what it does... Sounds good for a Rex but when ppl see it's a skyline it's embarrasing!
Its not a 2hr job lol u dont need to take the inlet manifold off, just the throttle body and use a whole heap of sockets. If u get splitfires and need a hand yell out and i'll do it.
Mitch, maybe the guy who sold you the car blew the previous rb26, got a cheap half-cut, threw in that rb26 and then sold it to you?
Crazy stuff dude.
nah he went from an rb25det to this rb26dett
will hopefully know whats wrong with it tomorrow, id LOVE to buy an rb26 from an R34 gtr but that wont happen.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
