*sigh*
well some weird stuff is goin on with the GTR. I suspect its the battery causing it.
Engine cranks over but the electronics in the car dont - not initially anyhow
when i put it in 1st and drive past 2500rpm for the first time, all of the instrumentation comes back on, the windows and aircon, indicators and internal lights start working again, but with the ABS, Hicas and 4WD lights all flashing.... then after a while all bar the Hicas light goes out and I'm back in action - albeit with a twitch hicas
I suspect that the lack of voltage in my battery (it was 12.5 last nite so I'm pretty sure its shagged - charged to 13.4volt overnight) is causing the electronics to stay off until they have enough power to run, and then they switch on. Its strange behavior but it would make sense in a way.
In either case, I've just bought an Optima yellow D51 battery. Hopefully that'll make the issues disappear - I'll know if thats the case or not later this evening.
Not cheap tho. $350. I know I could have got a standard batt but I've heard real good things about these yellow tops
-D
Alternator issue?
Have you replaced the light switch on the dash? I'm serious... mine melted and caused all the electrics to do crazy things. It's a common issue with the 32 GTR's.
Nah its not the light switch, and definately not the alternator. I get a 14v constant when driving. It dips when I turn the aircon on, for half a second, but I think its def the battery... it might have the voltage but not necessarily the amperage required.
-D
Hmmm yeah sounds more like a battery issue.
If your new battery drains in 60 minutes of driving, it'd be the alternator!!
Same thing happened to my mates Leopard. All of a sudden, things started to die, lights didn't work, started doing crazy things. Replaced the battery and bam, all good! An hour later, everything's dead again! Turned out the alternator just wasn't charging the battery.
Yeah I had alternator issues in 2007 just after I bought the car. The voltage gauge in the GTR dropped from the std 14 to 12 and the hicas cut out (hicas needs 13 volts to run).
Considering the instrumentation isnt coming on when the engine is off, but comes on when the alternator has put a bit of oomph on the current, its powering up a system that refuses to power up on a lesser current/amperage (not sure how theyve based it). I know the battery has been in there for longer than two years, and possibly longer than that (I'll have to check with writeoff if that batt came with the car - if its lasted more than 3 years then that kinda explains it)
-D
i thought that it was 3-5 years
Ideally yes, but the battery has been drained below 12 volts on several occasions - once you take a battery below 12volts, it very rarely comes good again, even the sealed gel batteries (which is what I have). The deep cycle batteries specifically can handle complete drainage (hence deep cycle) which is why I've decided to get one - so now my stereo hopefully wont interfere with the running of the actual car ;P
-D
Yeah once my current acid battery kicks the can, I'll get a gel-sealed deep cycle item.
Although, I'm not even running a head unit! Can't be bothered getting a CD player for the car. I'm quite happy with the sound of the RB26 with the windows down!
-D
Sheesh over the last 3 years that i have had the car for, the battery has gone below 11v many times lol
still going good though so hopefully still will be good for another couple of years.
-D
I've got 3 batteries in the truck with a combination of a high cca battery to start and 2 deep cycles to run my gear.
The deep cycle ones definitely do recover better than the cranking batteries but a deep cycle will struggle to turn over a hi-comp motor once it drains a bit whereas a high cca at the same voltage will turn the motor faster.
I've attached an article that my wife's Uncle gave me, he's a huge boat fanatic......haven't had a chance to read it yet but I will now.
EDIT: Tolerating low temperatures is not as much of a concern in cars as it is in marine use so the AGM battery probably would suit both worlds of cranking & house use over the Gel type......just a bit more expensive unfortunately.
Yeah, the Yellow Optima is an AGM dual purpose battery. I've heard of these things being left connected to a car for a year and then cranking over the first time (tho why you wouldnt disconnect a battery is beyond me). They also have a decent amount of CCA and a nice chunk of AH... so it should withstand my driving habits a bit better (I tend to do many short trips, so the battery doesnt always get its charge back - 15 minutes to and from work doesnt really charge the battery, especially when I have the aircon and the stereo cranked)
-D
Woohoo! Got my new gold chain for the Brutale today! ;)
Fitting it tonight when I get home then going ofr a ride to show off the new bling!
Man who do u think u are, Flava Flav on a bike? hahaha ;D
-D
-D
You know what time it is Roo!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
