Had a wheel alignment and puncture repair done at Adelaide Radial Tyres at Ridgehaven, corner Lower North East road and Hancock Rd. Excellent service, i was a walk in and they did it on the spot for me. $65 for a 4 wheel precision alignment and $25 for a puncture repair, had a screw in my tyre and didnt even know. Big +1 for them!
yeah he was telling me about the Holden Hill shop. They also sponsor a "josh" with a drift car? Also a distributor for Maxxis, 235/45/17 Maxxis Victra i-Pro retail there for $225 fitted and balanced. Wanted a printout of my stats but they haven't hooked the printer up to the new machine yet :D
Yep I got a couple of Maxxis tyres from Daryl last Friday. Always good, and prompt service.
Oh, and it is just North East Road, not Lower - that is a different road entirely.
does any one here have a r33 stock turbo elbow i can borrow or buy i need one to get my car back on the road and to get it tunned and i havent got much time 2 do it in even if i borrow it to get it tunned then my car sits till i get another one lol
yeh, i had the mistake of sending mine away with the turbo that was 'supposed" to be highflowed but didnt happen so now i got the gt30 highflow i need one again and ill b done
borrowed adrians (rad 32's) rb20 stock one hoping it would fit but a tiny bit smaller. thanks again adrian
I have one that I bought on eBay that I was going to use on a T2 turbo, but they are a different size. you can have it for the $40 that I bought it for.
niiice! adelaide radial tire are awesome been deeling with them since i was 16 when they had their old old store near golden grove.. daryl is always a pleasure to deal with. now im dealing with i think its mathew near holden hill. awesome bloke! currantly setting my R up with front and rear camber arms, castor arms, all bushes replaced, hicas lock and semi slicks!
+ 1 for adelaide radial tyre
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
