Cheers for that. I just got Ikeya formula ones myself, awesomely made and very tough, but thinking of changing to cusco as they have the dust covers. Will go Ikeya Lower control arms later, but don't really know anyone in adelaide who has the knowledge to adjust the roll centre correctly.
True, Ikeya arms are as tough as nails. Far surpass the factory gear. I have standard traction arms in the S14 and also in the 31. (Have 33 GTS-T cradle going in)
As for adjusting the roll centre.... it's not a case of something someone can do, the arms themselve have a roll centre adjuster built into them, which brings the roll centre back up to near where is should be. I dont have them in the S14, probably wont get them. My roll centres are through the earths core, yet it seems to drift fine. Nothing internally combusts or the earth stops turning LOL. I may put them in the front at some stage as my LCA's look like they're at a 45 deg. upward angle lol......
What you said is more correct talking about traction rods.... not too many people have the knowledge to set them correctly. I may get some later on, but a very low priority on my list of things to do.
Edited by R31 drift pig
i know you can make the steering wheel go in and out but that doesnt help i need it to go up more..
underneath the steering wheel where you pulled down the latch thing to make it go in and out there will be another one just next to it to move the steering wheel up and down
And from all accounts he charges through the ass for f**k all work. :D
Apparently his dad @ The workshop is the man to see. Cant remember what the name of the company was though.... Ill send him an SMS and find out.
bingo, i got charged a buttload to do not a lot (and the job only ended up half done on my trailer as it was), they used to be good but i would only recommend them if i knew the dad was going to do the work
kye, its not really that hard mate, but if ya want some help, get in contact with pete (marv). he'd be able to help ya out im sure, and he's only over at pt noarlunga. enough bribery with spirits would get him over to ya
id offer to help but wouldnt be able to do it for a couple of weekends
having bbq at my place today for aussie day, if your bored and want to come round hit me up with an sms or a pm if you dont have my number, i'm up near modbury/ingle farm.
Ofcourse it was on there behalf, were all the reason's why ppl have car crashes and that on the road, so chowing there doing something about it makes them look a whole lot better for doing nothing
Edited by HVN 032
omg the lights on the intersection of brighton rd and jetty road brighton are WAY out of wack
was in my mates car, we had a green arrow to turn right off jetty rd onto brighton rd, so natrally we went... but a massive truck came steeming up behind us with more wheels locked than i care to count.
went back there and watched the patterns, and sure enough, there was a green light for the traffic to keep going on brighton road, while it was showing a green arrow for ppl to turn off jetty road and onto brighton :S :S
my mate reported the fault... hopoefully no one got in an accident.... we were lucky
was it because you drive a skyline Carl that you see all traffic lights as green :P
do it Damo :D
lol, was in an 13bt RX4... i was the frightened passenger, with my a$$hole puckering like a blind knife throwers assistant
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
