Cheers for that. I just got Ikeya formula ones myself, awesomely made and very tough, but thinking of changing to cusco as they have the dust covers. Will go Ikeya Lower control arms later, but don't really know anyone in adelaide who has the knowledge to adjust the roll centre correctly.
True, Ikeya arms are as tough as nails. Far surpass the factory gear. I have standard traction arms in the S14 and also in the 31. (Have 33 GTS-T cradle going in)
As for adjusting the roll centre.... it's not a case of something someone can do, the arms themselve have a roll centre adjuster built into them, which brings the roll centre back up to near where is should be. I dont have them in the S14, probably wont get them. My roll centres are through the earths core, yet it seems to drift fine. Nothing internally combusts or the earth stops turning LOL. I may put them in the front at some stage as my LCA's look like they're at a 45 deg. upward angle lol......
What you said is more correct talking about traction rods.... not too many people have the knowledge to set them correctly. I may get some later on, but a very low priority on my list of things to do.
Edited by R31 drift pig
i know you can make the steering wheel go in and out but that doesnt help i need it to go up more..
underneath the steering wheel where you pulled down the latch thing to make it go in and out there will be another one just next to it to move the steering wheel up and down
And from all accounts he charges through the ass for f**k all work. :D
Apparently his dad @ The workshop is the man to see. Cant remember what the name of the company was though.... Ill send him an SMS and find out.
bingo, i got charged a buttload to do not a lot (and the job only ended up half done on my trailer as it was), they used to be good but i would only recommend them if i knew the dad was going to do the work
kye, its not really that hard mate, but if ya want some help, get in contact with pete (marv). he'd be able to help ya out im sure, and he's only over at pt noarlunga. enough bribery with spirits would get him over to ya
id offer to help but wouldnt be able to do it for a couple of weekends
having bbq at my place today for aussie day, if your bored and want to come round hit me up with an sms or a pm if you dont have my number, i'm up near modbury/ingle farm.
Ofcourse it was on there behalf, were all the reason's why ppl have car crashes and that on the road, so chowing there doing something about it makes them look a whole lot better for doing nothing
Edited by HVN 032
omg the lights on the intersection of brighton rd and jetty road brighton are WAY out of wack
was in my mates car, we had a green arrow to turn right off jetty rd onto brighton rd, so natrally we went... but a massive truck came steeming up behind us with more wheels locked than i care to count.
went back there and watched the patterns, and sure enough, there was a green light for the traffic to keep going on brighton road, while it was showing a green arrow for ppl to turn off jetty road and onto brighton :S :S
my mate reported the fault... hopoefully no one got in an accident.... we were lucky
was it because you drive a skyline Carl that you see all traffic lights as green :P
do it Damo :D
lol, was in an 13bt RX4... i was the frightened passenger, with my a$$hole puckering like a blind knife throwers assistant
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
