I do
morphett vale, pm me
Cheers for the offer, i'm at campbelltown so by the time i drive down there to pick them up and then drop them off i might as well as bought a set as their only around $40. Thanks again though
Anyone in the north have any spring compressors?
like these ?
ive got a pair but they are at a mates , ill get em back this week and you can borrow them if you'd like ?
Arse, shenanigans went on last night and I missed it :(
anyone going to the ben simpson cruise? i might drop by with a few work mates for an easy drive!
I'm going ;)
Hoping there'll be some other cars as slow as mine so I don't get lost :D
If last night was anything to go by it should be great weather for a drive tonight.
I'm going :D
Yeah me too...Went for a quick cruise last night, Henley etc was pumping.
cops were left right and centre at the cruise so i left! there was a white falcon parked next to me with SAU stickers, who would that be?
Yeah that is Luke (and Flick)'s car Son - that's where I disappeared to - had to go steal some fries off them at Hungry Jacks and have a chat.
Spewing I had to go out to dinner rather than cruise - but at least I came down to say Hi to some peeps at the meet-point :sick:
anyone else here got an rc drift car? got any good locations that you frequent with it? ive heard of an old rc drift track in regency area, anyone heard of it?
yeah , i used to race there with my cars
ill find a map of it after i finish dinner and post it up
Went out for a nice cruise last night about 1 till 5.30 ish this morning no cops around. Went down south it was a great night for it finally got to open the car that i just got up. Great night didn't see many cars out at all.
yeah you left at the right time! after you left cops were pulling alot of cars over outside the carpark and apparently traffic cops were comming or something. i thought since i wasn't gonna cruise i'll leg it as well
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
