yea mines used 2 make around that with stock turbo no lag at all, good fun
yeah but there is 2 more psi that can be pushed lol
but very happy.....cant wait to get a new turbo now
pretty good figure krish, should be fun. :D
bah, turbos. fairly sure mines rooted (or on its way to being rooted, still got a fair bit left in it). good excuse to buy a disco potato though.
Edited by scandyflick
Yeah I'd love to get mine hiflowed and rebuilt with steel turbines and nice bearings but for the price, a pair of second hand 2860-7's sound a whole lot tastier ;\
-D
yeah, hiflowed would be good. gt28rs would be better though i think. lol. meh, whatever i do, engine will be getting pulled and all the little things will be getting replaced at the same time.
Oops...
March 2008 clean-up of the Torrens found this:
rofl doesnt get any more bogan than that
I'm not sure if this is in the right place.....
Is Autobahn the cheapest place in Adelaide to get Motul engine oil?
I'm in the NE suburbs near TTP
Thanks
no go see the good guys @ auto Pro clovercrest top guys they normally have to order in motul but tell them Steve and his mate Luke send you and they will look after you, i normally get nulon synth thats a stocking item there are a few synth brands to choose from
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
