Would LOVE to come Luke but I just don't think the car will be finished by then (I'm so sick of waiting!) Just curious, did you organise this off your own back?
what u having done Luke??
Edited by ovrtym33
How much is it Luke? My car most certainly isn't up to spec, but might take her out for a bit of fun.
I take it you will have separate track time for drifters and grippers?
Would we be allowed to take advantage of the burnout pad in the middle if we needed to let some smoke out of our tyres? My tyres always come with way too much smoke in them.
lol andrew, that shouldnt be a problem, is wat its there for :(
cost is $300 each plus you need a Cams licence, day licence available for $25 on the day. And yes separate sessions for grip and drift.
and yes luke, organised completely off my own back.
:( Andrew you are awesome :D
Dan, getting the turbos, clutch, computer, injectors, AFM's, fuel pump, etc all put in. All standard parts of course
nice, it will be a rocket by the time u get it back
who is doing the work on it?????????
UGHHHHHHH!!!
REALLY want to come <angry face />
when do you need payments by ?
REALLY want to take my car out on the track without having to worry about 100,000 other cars being around.
as stated in first post ASAP, as i am currently near 4k in the hole. I have limited it to 15 people, so far i have about 8 i think confirmed so as soon as spots fill thats it. Only 1 has paid though so far, so money talks.
Edited by skylineguy19
Yeah Dan, should be sweet, doing a lot of the work myself, turbos however I'm getting Andrew (Blue32) to help fit for me :(
Luke, best of luck mate, mind if I ask a few of my mates to see if they are keen?
at his place???
apparently he lives around the corner from me and adrian in alberton
2 more days of work ... then a week off for World Superbikes at Phillip Island ;)
Leaving with a couple of mates on Wednesday night ... woohoo!!!!!!
Taking the Brutale and lots of booze over :blink:
Also damo isn't one of them cracked??
If that's the case then they are worth even less.
I think crack is all fixed up now, replaced with new one that is also white so it's all good.
I think anyway ;)
Yep its fixed, well replaced, they refused to fix the crack so i bought another rim and had it colour matched.
yeah, he's replaced the cracked one
i sold my black doriteks late last year with no tyres. pair 8s and 2 pair 9s for 1000 cash (as i needed the cash to get rid of them)
Decent sale price. I guess patience is a virtue, Craig's mate Adam might be keen so well see what happens.
found this info on the Mines R35 GTR from a USA performance car web site.
http://pasmag.com/index.php?option=com_con...&Itemid=105
the site also has some good shots of NS and a few other interesting rides,,,,, and the mandatory chicks to go with!!!!
not nudes for all you perves at work..lol
enjoy
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
