Yeah I gotta get mine replaced so I'll be lashing out for a set of RDA front slotted rotors too. Theyre not as expensive as I thought they'd be either.
-D
rda are awesome value get a full set of rotors for the same price of 2 dba
-D
Just got mine off the SAU group buy, in 4 days.lol
and cheaper for 4 then buying 2 from anywhere else in town
Ben look into the group buy mate
i got a set of 4 for my 33.....$***delivered and was here in 2 weeks
so definately recommend that guy in the GB section
"edited by SLED"
I arranged it last week thru the grp buy.
-D
Seriously?! Yeah!! Slotted are a shit load better than just standard.
Improved stopping distance, improved feel, etc. I even went from a cross-drilled set to a slotted set and noticed a huge difference.
They improve braking power, basically. That and a good set of pads!
Most properly modded street cars, you'll find with slotted rotors. As well as all the HSV's and FPV's that came out the factory, and a few BMW's.
everyone going slotted?
curious, do slotted rotors go through pads faster than standard flat rotors?
Well for me Damo the slotted rotors feel a whole lot better
i havent noticed much brake pad wear but only had them in for like 4 -5 months now
plus i had to go slotted as you can as luke (enr_034) how stuffed my stock rotors were mate
if anything they make the pad last longer. they do have more bite which increases wear but the groove also assists in cleaning the brake dust off the pad and venting it out so its not actually trapped between the rotor and the pad, and that itself helps the pad to stay alive a bit longer...
You'll still have benefits with cross drilled however many cross drilled rotors are prone to stress fractures due to the fact that they are drilled after the rotor is forged, whereas the slots are actually shaped within the forging/casting process. You'll notice RDA also have the gold passivated rotors with slots and 'dimples'. The dimples are done during casting and dont go the entire way thru the disc, so theyre much hardier. cross drilling isnt so useful for street work (lets face it, its there for cooling so its mainly for racers)... slotted is more than enough for any street car.. if your slotted rotors aren't doing the job on the street, then thats the time you consider caliper and disc diameter upgrades... or switch to a prius
I've already added a cusco brake cylinder brace and braided brake lines and those two improve the feeling/response of the brakes quite a bit. The new rotors should really seal the deal, I can't see myself needing bigger calipers or disc diameter...
-D
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
