Anyone going to the geelong airshow ?
now thats power.
FA18 super hornets flying over at mach1. half the speed they can go.
lovely.a
My GF and i are heading off on friday arvo but won't be going to avalon till sat morning... gonna go to the NAB final friday night.
Got Gold class grandstand seats :D
Did you see the special on telly on sunday from last years??
That's alright the people that need to know, know the validity. There are no details about my car anywhere online. There is a build thread on NS but it hasn't got any plate/VIN numbers on it and that is the way it'll be staying. Besides the details in the box that I have edited out are entered when you put the car on the dyno anyway so they shouldn't be taken as gospel anyway.
+1 :(
that would be fun in the hills
that would be freakn dangerous through the hills
Haha, awesome top!
group buy on RB shirts
my 2 cents, the SA section should be left for topics like the one that was locked, why? because we have a massive national section people should post threads related to cars in, because there gonna get a better answer and more help as its not just SA people answering....
let the SA section be for SA people to chat together
/please dont ban me :s lol
I can see at least 10 topics on the SA page that shouldn't be there. So why haven't they all been closed? This is a forum for people in south australia.
One of the threads you may be referring to might be Amanda's pregnancy thread, yeah?!
This thread was started well before the tougher rules were enforced and to shut that down now when she's ready to give birth would be plain heartless.
Karl, I have met you on the bikes one night and you seemed a together kind of a bloke but lately I've noticed that you only post when you have something negative to say.
As I said to you once before, take a deep breathe and engage some common sense before posting please.........friendly warning.
Pete I think the answer is to create an Off Topic SA section so people can create nonsense threads and and every one else isn't exposed to them. Do what NS does and make the section a non post count section, hell if this had been done from the start Damo and a few others would only have 5 posts and not the thousands currently they have (not that post count means anything).
We are all member of the "modified/performance" car community but that doesn't mean that we have to always talk about cars.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
