Had a look at a car with my mate, the seller also had a 33 GTR out the front of his house. I informed him that the lock and ignition barrels were stuffed which he didn't know! Some scumbags broke in and tried to start it, funny thing is, popping the bonnet, NO ENGINE :( He'd sent it off to be rebuilt, I would have love to have seen their faces :)
I heard them call it the R35 GTR but it is actually a "Nissan GTR" there is no such thing as a R35.
Yes no longer called a skyline.
Dave I have one of those knobs in my car and they don't take all that long too cool down once the windows go down even on a 45 degree day. And my car is black too!!
nismo gearknob, picked it up today, feels awesome. the momo's for sale if anyone wants it.
I have the leather version of that Nismo knob, cant stand it, to short, bad shape and slick, I can only image how bad that one is
thinking of molding something ???? other then the dildo from the 32 ,,,perves..lol
I picked up a battery at sprints just yesterday - $100... second one I've bought and does the job sweet - the first one i bought when the skyline just came over from japland had for about 1.5 years since and I only took it out last week to chuck into the daily.
i quite like, but thats just me. i think its pretty well weighted, height is spot on, easy to manipulate, i think its great.
Since where talking about knobs, this is mine. I like the way it feels in my hand on a cold day :(
Roads closed pizza boy :)
Thats a classic Luke :) Surprised they didn't get the shits and torch it or damage it in some way!
WHAT A BORING SATURDAYYYYYYYYYYYYYYYYYYYYYYYYY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
anyone alive????????????????????????????
Well, in a bit of shit... seems Nissan gave me turbo dump gaskets for an RB25, anyone got two spare RB26 turbo dump gaskets that I can get off them tomorrow? I know it's a long shot but I'd love to get the car back on the road
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
