Any one here used Potenza G3's, RE-01, Toyo T1R, Toyo R1R?
Im in need of new tyres and thinking of one of those tyres. Also are the R1R a semi slick?
thanks Luke
I run nothing BUT T1R's.... they are, imho, the best tyre out there for street users. There are better track tyres, but the Toyos suit my style..
Diff tyres will suit diff drivers... I know the eagle f1 asymmetricals are rated higher than the toyos in some tests, and I may give them a try some day, but I've been more than happy with my toyo t1r's....
-D
cheers mate, Need a tyre which can take track work also, until i get 34 gtr wheels with semi slicks.
the t1r's will cope with whatever u can throw at them - in a street scenario
they do lose traction during high lateral G cornering (usually when you have 215's - not so pronounced when ur running 265's)
they are one of the best wet weather tyres out there... however I'm curious about the test wheels magazine ran recently where they score the f1 eagle asymmetrical rather highly (i think thats the one?)... either case, it was an interesting report and I think if you're gonna get new tyres, you're going to want to read it so u can select the tyres u want for the specific application...
if you want info about track tyres, im sorry but i dont know anything about that... but ive heard the toyo r888 semi's are very highly regarded
-D
thanks Luke
Chef is using the R1R's on his GTR. From memory, they're borderline semi's.
If they're used on his GTR, then they must be nothing short of awesome.
grr..after searching through the 31 forums..and to no avail...what price would i be looking at for a good condition 20det box? with clutch/flywheel etc. someone said 500 or so..just thought id see what some people say on here..
PM this guy http://www.skylinesaustralia.com/forums/R3...ts-t262240.html
he has one for sale and is online right now :)
..::edit::..
he is not in adelaide, but is helpful and will be able to give u a price
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
