Any one here used Potenza G3's, RE-01, Toyo T1R, Toyo R1R?
Im in need of new tyres and thinking of one of those tyres. Also are the R1R a semi slick?
thanks Luke
My R34 came with 255/40/17 G3s on the rear and they were absolutely awesome in all conditions. Problem is due to the unusual size, when I went replace them was quoted over $400 each. Fail
im going the G3's on the silvia for the fronts next practice.
ill find out how they hold up compared to the bridgestones ive got now that after 2 track days, their already ready to be moved to the rear to be finished off haha.
You actually want to use a KKR turbo?!
Okay.
im using a kkr330 turbo on the drift car but the internals are all replaced with garret gt28 stuff.
pretty awsome turbo, comes on boost pretty hard all the way to redline!
Edited by Import S13
I went to look at a 34GT-T at Torque Motorsport on the weekend, ment to have done 64,000kms yet the interior was more warn then mine and i have done 109,000kms....
They wont give you any history either. Or let you drive it until you negotiate a deal, signing papers saying you will buy it subject to the test drive.
Why the hell does there have to be so many dodgy Skylines around. Gives me the shits.
Sounds all like Synergy Motorsport to me!!
Mate looked at a Supra, had to sign papers and put down a non-refundable deposit, etc after a test drive even though he wasn't keen on it at all after the test drive.
I'd steer away from them then. Sounds dodgy as. Reckon they've turned back the odometer?
you dont *have* to do jack. If you've driven it and dont like it, just walk away.... and if they point a firearm at you to make you sign it, the contract is void as per terms of duress
-D
Yeah I think there is something up. With KMS that low the interior should be immaculate, the wear on the steering wheel and gear knob was really bad and there were a few holes in the carpet under the drivers mat. Everything inside was more warn then mine.
The engine sounded healthy and looked clean but it could have been replaced. Cant drive it to test the gearbox which is a pain!
There was also a bit of the body kit burned/discoloured from the exhaust. My dad said it looks like a respray on it, and it only had one tyre guard which was a bit odd.
I tried to get some history but all they say is they get them from interstate and there is a privacy request....
rofl at privacy request on a used car.........I would've laughed my brains out all the way to the door.......and that would put me off any seller like that for good.
that's it just take your money else where! i buy my car when they let me test drive and if they seem a bit worried then i'll let them hold on to my license!
All imported cars look clean, especially the engine, after it's been blasted and cleaned in quarantine!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
