nero is the problem, even tried burning through windows, still = fail
hahah >insert witty quote about redheads and burners<
sorry but how is nero the problem?
If the burn fails during the procedure, your burner might be faulty.
If you can't even get the file into a filesystem template and prepare the image, then give up and hire a nerd for half an hour. Then sell your PC and buy an abacus.
-D
Dammjust got back from my regency appointment and failed :D.
Got done for tiwsted brake line but it passed the brake test.
6 x 9 speakers in the back so they cut the metal parcel shelf and parkers and low beam on 1 side.
Does any1 know hwo or where i could get to fix/ put in a new metal parcel shelf???
please help
Parked our car in Jetty Road, Largs North on Saturday afternoon.
We had two (2) Port Power season tickets sitting on the dashboard.
Some bastard broke into the car and LEFT TWO MORE!
A rebuilt high flow i would of thought would be better than a 2871
52T 2871 will do 250rwkw and a 56T will do 270rwkw, i don't see a high flow doing that. Garret rate them at 460 and 475 hp at the engine respectively.
Edited by D_Stirls
Wow.... I guess they couldn't have been true port supporters
after all, you didn't mention that they'd stolen your car radio :D
-D
please help
cut metal parcel shelf........you'll be lucky not to get black listed for that (as the parcel shelf is usually part of the structural steel
might be worth checking out what nisswreck can do for you though
heres the question scott, how did you not know your headlight was out? i can pick it on any car i drive (especially at night).........and i woulda checked all my lights before going anywhere near regency anyway
Dammjust got back from my regency appointment and failed :D .
please help
are you kidding me for 6x9's ???? that means you could defect a lot of cars in this town. I dont care for 6x9's but that is petty shite , its going to be expensive to fix labour wise unless you can weld, rear window might have to come out just to keep from breaking it ,, that sux big time
try a body shop for install if you dont want to attempt it
anyone have about 20-30cm or so of 3M automotive double sided tape laying around? The tough stuff they use to stick on car trims, etc. NEED some.
superchump doesnt sell the good stuff, not the one down south anyway
you need the red 3M tape , used for trim, call up any auto paint store for it, or rare spares on south rd
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
