Well just got my car back with the new dumps fitted... Massive props to Andrew at AM Performance, if you want a great exhaust and exceptional service, definately go see him! Not too long now and she'll be all done, just need to fit the clutch and get a tune :thumbsup:
hey ppl,
In Oz lotto, I brought a 25 game easy pick. The numbers that got drawn tonight can they be scattered on the ticket or do they need to be in one row?
Ive got all the numbers but scattered.
Million dollar question...
hey ppl,
im thinking one row...but then how would i know i dont lotto...waste of money me thinks
good luck tho
^^ lol
hey guys i just won $60mill im not going to be working any more things are good.
2hours later........................
hey guys can you stop calling my phone and asking me for loans and feeding me your sob storys. i need to make a phone call to pick up my money.
5hours later...............
spotted 16 skylines following my car around no matter where i go, is that you guys?????????? im getting scared i have a bag of unmarked bills.
2 days later...........
missing 1 bag of $60 cash if found will be small reward. someone rammed me off the road and took the lot :thumbsup: i thought we were friends guys
I buy a lotto eveyrweek, my only gamble
need the numbers in one line, sorry. won $666 in super66 about 8months ago
I figure $10 a week on a variety pick is $520 a year, hope to win that much back in dribs'n'drabs or more every 2 years
waiting for a 10k win one day, or more :blink:
hey girls, good to see u both back on here :blink:
im thinking of getting a new battery for my car. there is a relocation kit in there already but its not hooked up atm,
any hints on good places/brands for getting a new one would be much appreciated
Optima Yellowtop Deep cycle... I got one a couple of months ago. Not cheap but really good quality, sealed and with enough capacity to run yr subs at the drive in thru 3 movies...
-D
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
