thats weird when i clicked reply to my own post i see the link i added before but when i refreshed the page is had gone :)
http://www.hlj.com/product/hpr08077<<any ways thats the link
and one for ENR34 Luke ;)
http://www.hlj.com/product/KSH03252BL
well done Roo it sucks sometimes selling things
i need to buy a set of 4 x 5mm spacers tomorrow for the rolla.
where is a good place to get em cheap in the southern area?
Try AJPS in Lonsdale. Pretty sure Repco, Sprints or Outbound sell them to.
Edited by DSTROY
been covered a few pages back.
just got home, perused kellys club thread, found lots of 4 banger hate. sigh. srsly roo, just cause i drive a car with a small engine...
:P
hahathere sure is! but i might get a 4 banger when my car is done! i want a s14 s2, they are sexc as when done right
hi spec lip, navan skirts, navan pods, jdm s2 wing. win.
im fking sick of these immature little pricks who think cars are toys and try drift n shit on public roads
thank you for ruining it for the rest of us !
i cant f**kEN beleive you are saying this!!!!!!!!
when i met you i clearly remember you bragging to me how u were trying to "DRIFT" up and down Gorge road and i think i even remember u telling me you hit a post aswell
i think you are one of those "immature little pricks"
You not have a job again?? What happened now?
Oh im at work but trust me there's nothing happening damn automotive and damn gmh!
Better get use to it Shane. Big announcement tonight, GMH Elizabeth will be going to one shift only, Days and Arvo's will be on a weekly rotation. So one on at day shift rate (bout $150 a week less) then the following week at 50% pay.
Seems the auto industry in Australia is about to go belly up!
sucks to hear that james....doesnt look too promising at the moment does it though....
goodluck with it all fellas
Thanks Krishy
Yeah they're giving us more time off than a prostitutes knickers, pretty much treating us the same too :P
Thanks Krishy
Sorry to hear you've been effected but considering the lack of innovation in the australian car market, is it any wonder we buy 20 year old jap imports which have more features and better build quality than a current model australian made car?
;\ suck that a nation like australia still has its head up its own arse when it comes to automotive innovation
-D
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
