took that yesterday, was heading to the CSA cruise meet, and mid conversation with my mate im like "was that a f**king chopper driving down north terrace?" admittedly he thought i was on crack until we turned the corner
I had a played around with an Omnia. Some things are a bit small to press with the thumb so need to use the stylus which I found a bit annoying. Only thing that sets it apart from others really is the widgets I reckon.
Awesome game. Don't forget to turn up the sound! Post you high scores here.
Mine is 30 seconds
http://www.fugly.com/media/view.php?cat=DOWNLOADS&id=709
ahaha i had to play it...knew what was gonna happen and still makes u jump a little rofl
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
