Awesome game. Don't forget to turn up the sound! Post you high scores here.
Mine is 30 seconds
http://www.fugly.com/media/view.php?cat=DOWNLOADS&id=709
Category= Tastless Haha I havent seen that before
Access to this web page is restricted.
Category:
Tasteless Reason:
BLOCK_WEBCAT-DefaultGroup URL:
The department's Internet Usage and Monitoring policies identify that the access or use of internet services for prohibited or obscene purposes, or in support of such activities, is to considered to be inappropriate and unacceptable. Further, the department monitors usage of the internet and provides reports to Business Unit Directors relating to inappropriate use.
If you believe that access to this page has been inappropriately restricted, please contact the Shared Servies Service Desk on (08) 8226 5654.
was meant to go to Shane's place to watch it but couldn't make it as i have a cold and didn't want infect everyone.
hopefully will be able to watch it this coming monday at his place!!!
Its only early... had my first scan today... Nearly 9 weeks along. We'd been trying for a year to get pregnant. Ben is so happy. I saw its little heart beating... and tiny little legs starting to grow :D
We are gonna find out if its a boy or girl... ben isn't patient enough to wait!
So that would make you around 17 weeks then???
WOW congrats Nene and Ben!!!!
My brother-in-law's wife (he is Red Back on SAU and owns the grey R33GTR number plate VPSEC-3) had her 4th child this morning - a 4th GIRL believe it or not! Going to visit them tonight at Calvary.
I can't believe my 'baby' is nearly 18 months old - hard to believe how time flies!
4 girls... wow!!! i secretly hope for boys lol!! girls are way too much trouble!either way ben's already talking about buying "it" a go-kart!
18 months old hey... that seems like a life time away for us at the moment... but im sure time will fly
i hope for girl, im from a family full of boys lol
na not quite 17 weeks Nene, were at 15, we are having the 4D scan to determine the sex, just to make it that little more
exciting!!
congrats again, and congrats to Benny!! PRACTICE MAKES PERFECT!!!!! lol
ps, i still have Bens jacket...
Yeah for sure..
its pretty expensive, but well worth it!
otherwise, we would have to wait till 27ish weeks for the free 4D at modbury, and even then
we only get 1 photo..
with Fetal Fotos, we get pics and DVD to show off :D
ill pm a link to the site for later refferrence :D
just a quick heads up:
Driving home from Barker to Adelaide went through 3 cameras in the hills. I was doing well under the limit :D
2 on the road between littlehampton and balhanah and 1 on the lofty turnoff on greenhill road
Congrats Ben & Nene :D
Just got a phone call telling me i can pick up my car from the brother in laws paint shop, bonnet and boot done and all free of charge :D just got to put a couple of stickers on my car.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
