I LOVE SAU SA..lol..... every thread turns into, "the wasteland", slags, rubbish, for sale ad's, the list goes on and on... :thumbsup:
matter of fact, this is a wasted post too..lol
my 2c worth for the day
james i got a titanium cat back on mine only the cannon at the end and cat and it aint that loud at all it got a deeper note to it tho
Explain? Just the cat and the cannon are full titanium and the rest is stainless steel? How much that cost you?
Because of you Chad (yes, I'm blaming you :D), I am now $10,000 poorer.
I pick it up tomorrow night. So it looks like I'm back into another Skyline :bunny:
Cant wait!
The one JIS has is off a 33 coupe, full cat back system in 4'' Ti including rear resonator.
Because of you Chad (yes, I'm blaming you :D ), I am now $10,000 poorer.
Cant wait!
I remember following the build up of that, Kiers workshop was just down the road from my old work. Excellent buy there, if you get any dramas with it, go see Peter at JMS, he did most of the original spanner work on it
Because of you Chad (yes, I'm blaming you :bunny: ), I am now $10,000 poorer.
I pick it up tomorrow night. So it looks like I'm back into another Skyline :)
Cant wait!
:D good work, that car is real fast, very good buy for that price. :bunny:
Cant wait!
drive to my house yeah :) i still have that turbo timer if i could of got the bank to give me another 10k i would of bought it just for the engine :bunny:
i would take it to Willall before Peter
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
