the burn i did tonight is just one of those burns that a) is in a pain in the arse spot being that it is in the middle of my palm and b) i should have been more careful yes, but we were slammed at the time lol
Burninating, the country side
Burninating all the peasants
Burninating all the people
In their THATCHED ROOF COTTAGEEESSS
THATCHED ROOF COTTAGEEEEEES
And Trogdor comes IN THE NIIIIIGHT
-D
If anyone heres something:
hey guys,
Brothers house got broken into this morning between 10.30pm and 6am.
Can you keep a look out for:
- 2 TV's, one 42"plasma phillps and a 42" sony LCD
- "Police" Sunnies
- Sieko watch (blue back ground)
Some of the things missing are from a recent Japan trip.
If you hear anything of these going cheap let me know.
Cheers Luke
yeah GTR seats ftw and the juice is there
where about you picking it up from up near my way ill txt you tomorrow actually ill have to PM you as i dont have your phone still ill do that tomorrow
im picking it up kinda late-ish in glenelg and if its not heaps rainy tonight ill be driving around down south.
can swing past yours tomorrow afternoon maybe around 3 or abit before. ive pm'd you my number.
Mitchell park, Broke in through the side toilet window. Smallest widow ever also. Both TV's were upstairs and heavy as. He wasnt home at the time. They unscrewed the front door lock and walked straight out.
Crime scene is going around later.
sweet pics Tangles. Cant wait to see the results of your highflow/hybrid
cheers
manifold will be like this but the wastegate pipe will be closed, ie balancer pipe.
both highflowed rb25 turbos will be using hks actuators, therefore internal gate.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
