Have you tried knocking the gain back on the big muff for thrash? Sometimes it's more effective to lower the fuzz boxes gain level and drive the amp harder for a more "clean" (I know... sounds like a contradiction!) aggressive controlable gain that still sounds as heavy as all f**k..... use lots of low/mid EQ if your playing lots of 5th's.
I cut the mids and gain the treble and bass generally and use the gain as overdrive on the bigmuff and run it into the jmp1 on its clean channel and then into the low gain input of the amp... the cleans are what im after mostly, while using the big muff as only overdrive due to its sound in general. i know of loads of people who do use amp overdrive but other people live here so I have to be considerate and play at realistic levels ;P
Here's a pic of my hand built mic amp....
Looks interesting, from a kit i take it?
I'll dig out a photo of my custom Telecaster I built too....
My telecaster has 2 single coil pickups and one dual mode humbucker, each one controlled by an independant toggle switch (humbucker has 3 way) so I can get 11 variations in tone. Also has fender brand floyd rose which Im going to replace with an EVH Trans Trem... Might need to think about getting the tuners replaced at some stage along with a general service... need the electrics looked at cause when all 3 pickups are turned off there is some residual noise... and the barrel plug is worn as they always do... along with getting the top strap lug refitted...
-D
Edited by Dohmar
I'm hearing more & more stories lately of sensible peeps in modified imports not getting defected.
Me thinks they're judging you on the spot and making a pre-determination in their heads as to whether they think you're a hoon or not.
If they think you are one, you may come away with a canary......they obviously liked you James.
The only parts that came as kits to be assembled were the power supply and switches (these are universal and can be used on almost any mic pre), everything else I sourced and built. It's a clone of a very very famous circuit (Neve 1272) and I re-produced it as closely as I could possible with parts sourced all over the world. All aluminium internal components were hand fabbed.
-D
Nice guitar, I love tele's. If you're after new machines (tuners) have a look on ebay for Sperzel locking types. Not sure whether you have a preferred guitar tech, but I only ever let Steve Salvi (Salvi guitars - George St Thebarton) or Brian West (Fretco) near any of my guitars
My 2 Levinson Blade strats have that sort of arrangement with coil split humbuckers in the bridge and onboard preamp/eq via 3 way toggle that switches 2 variations of active settings as well as passive. Both also have locking machines. Only my Tokai Talbo has standard machines and one day I might swap these also for locking types.
My custom built Tele has Sperzel locking machines, EMG active pickups, Fender USA - Bridge/Neck Plate/Control Plate and USA made Fender licensed Alder body and a vintage style 1 piece maple neck and finished with a vintage style 5 hole single ply pickguard.
Custom Tele
yeah dave got the PM mate
will let u know asap
i had an exhaust leak a while ago and yes it sounds like one of those road trains lol specially on boost
BTW love the internet at the airport.....
Edited by Krishy
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
