Have you tried knocking the gain back on the big muff for thrash? Sometimes it's more effective to lower the fuzz boxes gain level and drive the amp harder for a more "clean" (I know... sounds like a contradiction!) aggressive controlable gain that still sounds as heavy as all f**k..... use lots of low/mid EQ if your playing lots of 5th's.
I cut the mids and gain the treble and bass generally and use the gain as overdrive on the bigmuff and run it into the jmp1 on its clean channel and then into the low gain input of the amp... the cleans are what im after mostly, while using the big muff as only overdrive due to its sound in general. i know of loads of people who do use amp overdrive but other people live here so I have to be considerate and play at realistic levels ;P
Here's a pic of my hand built mic amp....
Looks interesting, from a kit i take it?
I'll dig out a photo of my custom Telecaster I built too....
My telecaster has 2 single coil pickups and one dual mode humbucker, each one controlled by an independant toggle switch (humbucker has 3 way) so I can get 11 variations in tone. Also has fender brand floyd rose which Im going to replace with an EVH Trans Trem... Might need to think about getting the tuners replaced at some stage along with a general service... need the electrics looked at cause when all 3 pickups are turned off there is some residual noise... and the barrel plug is worn as they always do... along with getting the top strap lug refitted...
-D
Edited by Dohmar
I'm hearing more & more stories lately of sensible peeps in modified imports not getting defected.
Me thinks they're judging you on the spot and making a pre-determination in their heads as to whether they think you're a hoon or not.
If they think you are one, you may come away with a canary......they obviously liked you James.
The only parts that came as kits to be assembled were the power supply and switches (these are universal and can be used on almost any mic pre), everything else I sourced and built. It's a clone of a very very famous circuit (Neve 1272) and I re-produced it as closely as I could possible with parts sourced all over the world. All aluminium internal components were hand fabbed.
-D
Nice guitar, I love tele's. If you're after new machines (tuners) have a look on ebay for Sperzel locking types. Not sure whether you have a preferred guitar tech, but I only ever let Steve Salvi (Salvi guitars - George St Thebarton) or Brian West (Fretco) near any of my guitars
My 2 Levinson Blade strats have that sort of arrangement with coil split humbuckers in the bridge and onboard preamp/eq via 3 way toggle that switches 2 variations of active settings as well as passive. Both also have locking machines. Only my Tokai Talbo has standard machines and one day I might swap these also for locking types.
My custom built Tele has Sperzel locking machines, EMG active pickups, Fender USA - Bridge/Neck Plate/Control Plate and USA made Fender licensed Alder body and a vintage style 1 piece maple neck and finished with a vintage style 5 hole single ply pickguard.
Custom Tele
yeah dave got the PM mate
will let u know asap
i had an exhaust leak a while ago and yes it sounds like one of those road trains lol specially on boost
BTW love the internet at the airport.....
Edited by Krishy
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
