F*********************ck
Dropped my rim tonight on the outer edge that shows. Fell over when cleaning it. GRrrrrrrrrrrrrrr
well since they are now damaged I will offer you $1,500 for them Luke :wacko:
i must also add that the supercharger im getting has a maximum boost pressure of 26 PSI and the power may be more if you included the fact im stroking the engine to 2.7 L
um you know you need to deck to block to get 2.7lt out of it you cant just stuff GTR crank rods and pistons in a rb25 and stick a head on it but i imagine miltons knows that
while people are telling you what youll need i hope you've thought of these 2 things
are you toying with the idea of tripple carbies mmmmm
Anyone taking bets that Terry Wallace won't be coaching the tigers this weekend against the kangas?
SLED, can we (someone) start an AFL 2009 thread?
-1
go to >>Here<< for all your football needs :wacko:
lol James...sell both your kidneys mate lol that will make up for it
Now there's an idea, two less organs to worry about i guess! lol
Hey pete, check the 'cruiser vid i found in the youtube thread, maybe more to your liking!
Edited by Jamesrb25
lol I was perusing the webz for a few ideas on another possible build and I came across this dude in QLD building a bike in his workshop with a poster of my bike on his wall......haha, I wonder if he wants some nude pics of me to go with it :woot:
