whereabouts??
funny you said that cause Zouma rang me last night (they were good buddies in the force) and was telling me some pretty gruesome stories about some of their work lately >_<
be hitting the boozer at warradale barracks about 1 (by the time we get back from the march and hav unit photos done n stuff).
and for randomness, this is the damage i inflicted
Regency needs demolishing - I just got failed with my Cedric because....wait for it....no English owner's manual...
Kinda like failing for a little bit of surface rust on the engine number tag... >_<
If you wanna stand out at AJD.
If you wanna stand out even more... 'OH SHUT BRU!!'
Edited by AndrewJZX100
he may be trying to get the car complied... in which case there are a whole lot more hurdles you need to jump threw, 1 of them being and english owners manual
There would be a lot of JDM only cars that wouldn't have a english owners manual. For instance there isn't a 1JZ english workshop manual in existance so i highly doubt that there would be english owners manuals for any 1JZ equiped cars when there aren't workshop manuals.
Also there are no english owners manuals for 180sx's there are english owners manuals for 200sx's and 240sx both of which are the same car but none for an actual 180sx.
Edited by D_Stirls
Dale, my 100 came with a 'owners manual' as it was a test car. It was all of about 5 pages basically saying 'put petrol in the petrol tank, oil in the engine and coolant in the radiator'. Just another stupid 'rule' to make it that little bit harder to import.
Also, while we're reliving the days of REAL comedy on TV...
LOL sau fails @ embed
lulz.
i have that spoiler. shame it wont be painted til next week. :/
>_< Milo FTMFW !
Sort of reminds me of some of the people i see in Elizabef :/
Edited by Jamesrb25
Thank you to everyone concerned for my welfare. When a Jap import is registered in SA for the first time, our lovely inspectors go over the Consumer Information Notice (paperwork from the compliance workshop) and cross check that everything is done exactly as is written, right down to the brand of tyres and the sizes. Mine said on the paperwork it had a translated English manual and it didn't so I fail. I'm sure you can imagine the phone call to the workshop after that one - it's coming down overnight via Express Post...
so is it still gonna be making an appearance on sunday? id really like to check one out. >_<
thinkin i might buy some new wheels next week, theres a set of 17 x 9 +20 grenades at JIS...
Yep, as Chef pointed out when every car is complied in Aus it MUST have an English manual supplied. Mine was a 10 page photocopied and stapled pos, but meets the letter of the law.
Andrew, from what I gather, you don't have to have one unless it has been mentioned in the Consumer Information Notice compiled by the compliance workshop.
In other words, Regency are nit-picking and should be blown up!
^^^Pretty much.
As I was saying to the girl behind the counter at the ID inspection place (who I later found out had had her own car impounded at one point haha), the Cedric will be a much nicer car once its about a foot lower, has a guard roll and has the 19s on. (Stich Kamfer, 19x8.5 and 9.5 +26 all round, ex-Japan, for the wheel Nazis...)
This one may be up for sale sooner than I thought - it turns out that buying a car and forgetting to tell your wife is not a wise thing to do...
Edited by Iron Chef
so is it still gonna be making an appearance on sunday? id really like to check one out. :banana:
buy my te37's :bunny:
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
