^^ does he even drive it apart from onto a dyno :/
hahaha yeah
they just did it with all stock stuff and he couldnt brake so they upgraded to the slotted rotors and better pads and that made him stop lol mind u this was all on the street too!
Edited by MissR34
the thing is luke, i wont be tracking or dragging her, she will be dyno queen and streeter.
so ill be going with Brembos and maybe EBC Red Stuff brake pads......
Brembos are great, but make sure u get a large rotor to match those sweet calipers
and avoid the EBC Red's... theyre track pads
if you're streeting, stick to EBC greens/bendix ultimates or the QFM pads
-D
ive been told to stay away from EBC greens cause they are too noisy and create alot more brake dust than the reds?
I used Red Stuff on my R and they were brilliant.
Very clean on the wheels too (ceramic pads), unlike Bendix, and can handle both street (low coefficiency) and the ocassional track day without fade (high temp handling).
Were a bit noisy for the 1st 1000km but quietened down eventually and grabbed those rotors hard and fast!
sick, thanks for that Pete, i rekon ill get the ebc reds for sure :/
rb stickers, dosnt anyone like sleepers these days :/
i prefer the dont need to brag about being able to whip your ass at the lights approach.
but then it might get 1 or 2 bogans to accept they cant beat you and not rev you at the lights
Edited by Inline 6
yeah you make a valid point, but then ppl still dont believe its a gtr anyway. love it when they ask me, if im lying with the badge why would i not lie when you ask me
i did rock no badge for a lil while :/
Edited by Inline 6
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
