Mathew, I don't know who you bank with but I'm with the CBA and if you have enough business with them you may just qualify for a wealth package which includes a Viridian - In Line of Credit style account at approx 5% for up to $50K
I'm with ANZ and the business is with ANZ at the moment, Im hoping to not need the overdraft much as I will not be running accounts with customers... no cash no car. Simple as that.
I'm yet to speak to the ANZ but I will speak with the manager tomorrow at lunch and see what he thinks are my best options as there will have to be a mock agreement written up before I can do too much I would think
Edited by Stagstock
Dont you hate when you lend a fellow SAU member 2 Parts (roughly $700 worth) to get through Regency late last year, and after countless Pm's they never reply, call, drop the parts back off. Starting to Piss me off. Now i have to search around for his number and see what happens. :D
Sounds like your pretty trusting luke... mind you I've been caught in the same situation.. sometimes your generosity bites you in the arse.
sux to hear man, hope u get them back asap
thats why i dont lend out any of my stock parts, unless im good friends with them
LMAO.. ^^^ I'm so glad im not the only one who has to do that. ' Oh look honey there's *insert accomplace here* ... what a suprise... we should go say hello' lol
Edited by Stagstock
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
