Hot4's have redesigned themselves again?
I haven't picked up a Hot4's mag since issue 101...
I still read HPI occasionally, although that's slowly going downhill... that mag used to be awesome until they started bringing in the Supra's with tanned leather and 22" Vault rims
yeah they have, and personally i dont think for the best either, it just seems like they have gone done the path of "gangsta" style, and stepped away from it being all about the cars and the model of the month kind of thing
HOT4S blows goats, did about 2 years ago
HPI has started going downhill too
Started buying Australian 4WD Action magazine. for the same money i pay for HPI (well, its now just PI really) i get 260 pages of good stuff
hahaha you goober.......I do too!
ive got 4 days. should be fun. might get around to fixing the 200. order some parts. head out south and check out the new place. and a friend of mine will be down from ireland on my next lot of days off. win.
4 days off sound really good right about now
specially after 4 weeks of being on the road....it starts getting to you....
Ohh and sled i got a score of 33 on a 27 9 hole par 3
ohh and i was trolling through my pics and found this :blink:
Edited by Krishy
hes so pretty. :blink:
*saves and uses as desktop background*
in other news, started work on getting my turbo studs swapped out. seems ive blown a fair portion of the gasket away. hah. got as far as removing the hot pipe, heat shields, and one nut. having trouble now. lol.
Edited by scandyflick
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
