easy to get the parts and have it engineered for road-worthyness, all GTT as you've mentioned.
just dont see the 500rwkw point tbh.... whats wrong with a stomping manual rb25det fully built with 300rwkw?
hell Id be dropping in a fully forged RB26DETT myself, twin GT3076's, high-300kw if it was my project.
gotta say 240rwkw in an auto, rb25det with single GT3076, mmmmmm NiiiiCE :D
gotta say 240rwkw in an auto, rb25det with single GT3076, mmmmmm NiiiiCE :(
:D
i just wanna get to know about turbo's a bit more
ill prob end up stripping down the N/A engine and doing whatever with it - havent really thought about it yet.
ill keep it stock and go from there i think :)
This afternoon I did a few things to the 32 (Also discovered it has an exhaust manifold leak :)), including cleaning the AAC, and AFM, but I have a question about my air filter.
I have a K&N pod, I cleaned it with the detergent, and it is in the shed drying overnight. Do I put the filter oil on it before refitting it to the car? I have heard people say it wrecks the AFM or something if you do, but I'm just after some clarity so I know for now and the future. I am using a K&N recharge kit.
Any help would be greatly appreciated :D
ah not really a waste of time
So that means my car was a waste of time aswell? me and a lot of other people think that engine conversions aren't a waste of time.
AWD, RB26DETT in a car that looks like a GTST, FTMFW! :)
dude, go tell that to every other person out there that does engine swaps in cars.
I'm pretty sure I wasn't referring to every instance of an engine swap. In 99.9% of circumstances I agree, engine conversions/swaps are NOT a waste of time and money. :D
u never had it either fishy, you never had your car :) granny shifting.......you know how it go's
hows the vspec looking these days? got stuck into that motor or what?
actually your right, i've never heard my car make those stupid flutter noises!! =D
and im not sure how its looking... dusty i presume.. i dont think i've seen it in well over a month and same with motor, nfi what happening with it =\ its all a bit depressing really =(
bloody breatho setup on pt road and down my street!!! WTF
so ppl cant pull into side street before the breatho..
i got pulled in to the one in the side stret in the falcoon..
bloody bastards..
bloody bastards..
I completely disagree - I wish they had the resources to put up 200 breathos every single night.
If you have more than 1 drink an hour and drive a car, then you are a stupid f**king tool who deserves to die. The number of people who still drink drive is bloody insane, and the worst thing is that the vast majoirt of accidents they are involved in the other party dies, and the drunk person survives .... this is completely the wrong way it should be.
There is no excuse - I actually wish they made the law 0% tolerance, like many other coutries around the world. If you want to have ANY alcolohol to drink, then don't drive. Make other plans. It is as easy as that.
I think they should quadruple all penalties, effective immediately.
or i couldve just sucked at fitting it last time. ha. ill borrow a scope from dads work and have another look. are the rear housings the same size between 25/28's?
edit, more quick research, 25's have .80 rears, 28's have .64's, definitely remember mine being .64, so i dont have a damn clue how or why it didnt fit before.
Edited by scandyflick
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
