i could do that eventually but atm i would rather get the stock gtt engine in and go from there too cause i can use the head off the N/A engine for the 25/30 combo
so are you putting a GTT engine in, and building the 25 N/A head with 30 bottom end?
I wanna do a 25/30 build too. Lets do it together Cara :P
Would like: RB30 bottom end, RB25 top end, cams, cam gears, top mount manifold, HKS 3071 ... as a starting point.
But which car to put it in :)
morris oxford...power to weight like strapping a jet to a skateboard
Cara,
You should have a look at the lewis engines website as it has got me thinking right now.
www.lewisengines.com.au
here you go Cara, from their website:
TRUST TDO6 used two hours after rebuild. made 340rwkw on rb25 @20psi. $800.00
RB30/25 'TORQUE MONSTER' engines $6,900.00
Dis wat u want??
looks the goods :P
I wanna do a 25/30 build too. Lets do it together Cara :)
But which car to put it in :P
sounds like a good idea ruby :D cant wait lol :P
might have to check that out a bit more damo, cheers
oh
btw
what do you think would be better?
apexi power fc boost control kit (for about $730) or greddy profec b spec II boost controller (for about $579)
let us discuss.
:P
Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
Thinking of building a little project myself ...
RB20 block
RB25 crank
RB26 rods
Forged pistons (1mm oversize)
Ported head
Adjustable cam gears
Custom cams
Top mount manifold
HKS 3071 turbo
... for starters!
Want car to put it in? :P
cara is like a little boy that listens to backstreet boys, while wanking off to a picture of britney.....doesnt know what she wants.
thats my take on it anyway.
now, my LAST attempt to get this footage from sat night up on you tube, if it doesnt work, im gonna give up!
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
