i could do that eventually but atm i would rather get the stock gtt engine in and go from there too cause i can use the head off the N/A engine for the 25/30 combo
so are you putting a GTT engine in, and building the 25 N/A head with 30 bottom end?
I wanna do a 25/30 build too. Lets do it together Cara :P
Would like: RB30 bottom end, RB25 top end, cams, cam gears, top mount manifold, HKS 3071 ... as a starting point.
But which car to put it in :)
morris oxford...power to weight like strapping a jet to a skateboard
Cara,
You should have a look at the lewis engines website as it has got me thinking right now.
www.lewisengines.com.au
here you go Cara, from their website:
TRUST TDO6 used two hours after rebuild. made 340rwkw on rb25 @20psi. $800.00
RB30/25 'TORQUE MONSTER' engines $6,900.00
Dis wat u want??
looks the goods :P
I wanna do a 25/30 build too. Lets do it together Cara :)
But which car to put it in :P
sounds like a good idea ruby :D cant wait lol :P
might have to check that out a bit more damo, cheers
oh
btw
what do you think would be better?
apexi power fc boost control kit (for about $730) or greddy profec b spec II boost controller (for about $579)
let us discuss.
:P
Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
Thinking of building a little project myself ...
RB20 block
RB25 crank
RB26 rods
Forged pistons (1mm oversize)
Ported head
Adjustable cam gears
Custom cams
Top mount manifold
HKS 3071 turbo
... for starters!
Want car to put it in? :P
cara is like a little boy that listens to backstreet boys, while wanking off to a picture of britney.....doesnt know what she wants.
thats my take on it anyway.
now, my LAST attempt to get this footage from sat night up on you tube, if it doesnt work, im gonna give up!
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
