i see you were lucky enough you got your comment published... mine got rejected as usually and it was pretty much only what i wrote in post above  :)
they usually only accept comments supporting their side of story... and i thought newspapers were not supposed to be biased...
seriously, just about anyone could become journalist in australia looking at quality of journalism here... hoon stories in advertiser and bra stories on ACA seem to be australian journalism at its peak...
the message here is if you are a retard that repeated every school year 3 times, failed at just about anything, dont have any qualification/education whatsoever but are not in physical shape to do anything with your hands: become a journalist or a cop... or maybe a road safety minister
You can also be all these things and still get a license to drive a car...
i know theres alot of well knowledged people here on turbos...mine shat itself this arvo....ebay special "team badrun" T04e with internal gate and v band thingo.....im looking at the monsta brand atm
http://cgi.ebay.com.au/MonstA-T3-T4-INTERN...%3A1%7C294%3A50
this is exactly what im looking for and pretty much what i can afford....any ideas???
dont do it Ben monster turbo are shit, see Bill at adelaide turbo services and get yours rebuilt
what do you reckon it would cost roughly???...by the look of it, its the rear oil seal.....maybe i could get mine hiflowed as well... :)
Cara, don't do this DE+T bullshit. First it will never be legal, emissions will be totally different to a DET motor so you will have to rip all the shit out if you get defected. Second, the motor just isn't up for it. Bite the bullet, buy a DET and be happy
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
