Does anyone have or know of anyone that has some bolt-on spacers lying around I could borrow for a short time to see what size I need? I would really like to see some 20mm's on, but don;t want to for out the cash for some until I am sure. It would be much appreciated.
ive got sum 5mm spacers here brand new u can buy for $15, nothing special brand got them from sprints auto
hey all... just quickly..
pulled the CA18det out of a bluey, running 100%.
put it in the rolla. now i idles like crap and missfires..
changed plugs..
what could be the problem?
any ideas?
was your car at "complete exhaust" (carline) today adrian???
saw it there this morning while i was getting my external gate screamer pipe open to atmosphere again by Michael
he does GREAT work there at great prices
that it is all.
My name
Is flubba bubba wubba jubba noongahhh!
Im BACK
Run! Run! Run!
Run Gordon!
Its the policeman, we gotta get up out the jails its policeman
grab ya bong, get the weed, its police man!
-D
Does anyone have or know of anyone that has some bolt-on spacers lying around I could borrow for a short time to see what size I need? I would really like to see some 20mm's on, but don't want to fork out the cash for some until I am sure. It would be much appreciated.
I have some 5x114.3 20mm spacers you can borrow but you will have to find some nut for then as i have used the nuts for the spacers i made on the CNC.
morning all!!!!WOOOO half day today...got the wifes falcon and a trailer load of rims and tyres that i have to swap over down at grand auto...pick up a battery....load the kids motorbikes and get ready for stansbury....i bet this morning will go slow as hell now :)
Collected 2 of my Design and Construction Management projects last night from my lecturer and scored top marks! :):ermm::banana: Funny thing was that I was worried I had left some detail out.
Projects required compiling a Site Analysis Report detailing everything about a development site from a site visit and survey. Next part of the project required the design of a single storey dwelling on that site, complete with all drawings you'd submit with Council for Building Rules Consent. Ah, I felt like bragging. Not often you get 100% from design projects. :cool:
Now I just got another 2 to go!!! Time for beer tonight!!!
[end bragging] :P
Edited by RubyRS4
yep that was mine!
and yeh he does! and FAIR cheap!
Today is not a good morning for me.....got into work and so much is needing to be done that its not funny.....plus going for another interview at 3pm then go home and clean the 33 for tomorrow......
here is a pic of a single story dwelling.
But thats only the front elevation! :banana: You haven't labelled the roof pitch, or dimensions of the window and door framing and the pier and cavity locations for those openings. You'll also need to annotate the construction materials and dimensions. Is it steel frame or timber frame? What grade wood?
Where are the site plans, elevations, floor plan, section plan etc?
And on and on ... :cool:
E- for your efforts :)
lol.....i spose that's what youd expect from a magna driver....jk
:ermm:
Edited by RubyRS4
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
