Life Story entry #319: thinking of going to the Blokes Expo this weekend.
Who else is intending on going to the Blokes Expo this weekend at Wayville Showgrounds?
:P
Yeah i am thinking of going out there and having a look see
whats the bloody point, theres no chicks there
I think you will find the complete opposite on this expo Dan
just in case anyone here is interested...http://www.nissansilvia.com/forums/index.php?showtopic=389082
Ya can't sneak it in that way ... its gotta go into the for sale section. :P
bahahaha nice try i would say that the mods would be onto this.....take it to the FS section mate
cooling pro? have fun fitting it.
ive had to remake all my pipes, either because theyve had huge welding dags inside the pipes, have been too long, or have been bent at the wrong angle, on top of having to make my own brackets, replace 2 silicon joiners, and source my own bolts and spring washers. all with the following response from jjr; "you get what you pay for."
Damo's kit that Jenkies and me installed went in ok, cooler pipe just rubbed on the fan a little. Intercoolers are about the only cheap parts i would fit to any of my cars.
No too obvious, but maybe it was so obvious that he got one, knowing we would think it was obvious and come to the conclusion that he didn't, when he actually did.
Confused yet? :mad:
Hint: its not a volvo ... its not a brap brap!
It has 4 wheels and 4 doors ... and a turbo!!!
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
