andrew, trade you the s14 for i... wait, its auto yeah? never mind.
anyone know if a s13 diff will fit in my rolla?
need something stronger
r31 diff. cut and relocate the mounts. voila. hilux diffs should work too.
Sooooo, if anyone knows anyone who might be interested in buying my R34, please let me know. Taking quiet "eio"s at this stage, as I don't really want to sell it, but have my eye on something different .... mine makes 230rwkw and I just added up a shopping list of mods I have done to it and it totals around $12k of extras. I am hoping for around $25k.
Asshole, 'sif you won't tell :P
R35 GTR in gunmetal grey? :P
so the only thing u gotta move is the dungeon toys and the gimp u got chained in the basement? :) Best to hire a ford panelvan and do it during the cover of night
-D
Nah, got it all to fit in a Hiace during the day :banana:
just found some really old pics of my old ET pulsar. bout 4 years ago.
thinking of getting another one for some stupid reason. daily maybe
Hehe Awesome. I love flashbacks :banana:
I got one too. 1988 TX5 Turbo
I got this car when I was 15, did a few things to it: 2.5" zorst, HD clutch (already in), TS VeePort BOV, Boost Gauge etc. Full sound system. That thing had balls. I was its 3rd owner, with the previous owner owning it since 1990, but it was starting to show its age a bit in 2005. So I got it a full respray to freshen things up a bit. Sometimes I regret selling it, would be an awesome daily. Good Times :)
When I got it
When I sold it
Edited by 93GTST
Laptops people. Who makes good ones? Dont need no top of the range shit. Just basic stuff. Would be good to play alright games etc Roughly around 1500ish to spend. And where to buy?
Toshiba Satellite A300. Got mine for $1400.
http://laptops.toshiba.com/laptops/satellite/A300
HAPPY BIRTHDAY CARA!!!!!!!!!!!!!!!!!!!!!!!!!
Try calling Darren from Print and Media Warehouse. They're good with laptops.
Or also try Grays Online. I got my last two laptops from them ... cheap!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
