indeed pedistrians are stupid in town, take it easy on em though tiger the way your story is written it sounded like you coulda dodged her :D
and i bet i can top your score at the carmageddon
Edited by Inline 6
I'm sorry Valentino Rossi...
No need to kick up a full stink, just the way you posted made it sound like you were bragging about knocking over a pedestrian rather than hurt your precious bike.
In anycase, enjoy your Carmageddon, get some practice in for the streets :D
Yeah, will do champ.
Next time you think you've misread something, ask me to clarify. Instead of you kicking up the stink first eh? :(
Edited by RubyRS4
Butting into something that has nothing to do with me
Yeah it f**ks me off when dudes dont pay attention when they walking - everytime Ive had a near miss with a human, my heart jumps into my throat and I have to suppress the urge to vomit
that said, if someones a dumbass and walks in front of my car, im going to brake and swerve and do what i got to, to minimize damage to them and myself
Ive been dumb enuff to be hit by a car before and man, it really f**king hurts. you bleed from every orifice for several days, get covered in a square kilometer of bruise, and it hurts just to take a shit.
nobody DESERVES that. i can agree with rubys sentiment, that if yr an idiot u deserve to get hurt, but I dont agree with proceeding heedlessly just to prove a point.
when i was 14 and I got hit from a dude at 40 kph, that dude was on the phone every couple of days to see how I was, and I was telling this cat not to worry cause accidents do happen
Shit happens. Faeces occur. However if I could nudge a dickhead without causing them harm, I probably would by principle - and therein lies the conflict
-D
not taking any sides here, but in a car you can turn the steering wheel 45 degrees in a split second just before impact......you try that on a bike and you go high side over the handle bars with every chance of spearing the ground head first :)
thats why i stick to cars and not bikes ;)
my balls arent big enough to provide star trek-like inertial dampening and testicular shielding
-D
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
