do it. only have 3 spaces left.
those little bread dinner rolls u buy from the supermarket frozen
chuck those buggers in the oven n toast em and chuck in some shaved chicken and jarlsberg
pimpin.
rick james never had it as good as me - this post is 4 ruby haha
-D
may need one on the way home if my gearbox goes bang.
Your gearbox wont go bang, my gearbox crunched 3rd from the day i brought it. I worked out i just needed to shift slower. 4 years later and its still working fine :P
^^you mean from 1st to 2nd? it's normal when cold... i think double clutching is a way to get around it
Yeah from 1st to 2nd, especially at higher revs. but also going into 1st like at traffic lights etc. But it seems to have stopped crunching/grinding all together now so Im happy with that :P
Dropped the mrs of at work this morning and for some reason the car felt like it had heaps more poke than normal.... I don't know if it's just me but the car seems to behave differently (response wise) on different days lately....hmm!
Well Im off to buy some oil and a filter today for the 32. Searched SAU on what oil would be good for a RB20DET, that just confused me more lol. The car has 158k on it but its been extremely well looked after. As far as I can tell, Motul Turbolight 4100 would be good for it.
If anyone has any suggestions, that would be greatly appreciated, otherwise I'll just get that.
I spoke with some lads some time ago about the Motul oils. The 4100 is good for 10,000kms but who's going to leave the same oil in their car for 10,000kms? 8100 is half the price and is changed twice as often (every 5,000kms). The end result was: with the 8100 the two oil changes every 10,000kms (5.000kms each) mean you'll have fresher oil more often.
So I stick with the 8100 every 5,000kms. Same cost in the end.
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
