why is sau sooo boring tonight? lol
Because I'm not taking the bait from the trouble makers :happy:
I've been busy with homework/paperwork myself, so haven't had time to stir things up ;)
Adj. cam gears is about the only difference mate. I'm not running a D'jetro, but apart from that I beleive that mod wise we are the same. You are running 18psi though aren't you?
Yeah 18psi, I may get cam gears at some stage, I'm not to fussed really. I'm very happy with how it is power wise, just want to get the suspension set up better for the track,
