thats f**** disgusting.
423awkw makes up for the less than tasteful body styling.
im sure it was all the rage in the show circuit at the time, difference being, its a show car that has the balls the tear up the actual circuit.
in conclusion, i couldnt care less what it looks like, its awesome.
Edited by scandyflick
wheels fail
wing fail
kit fail
bonnet fail (purposeful sorta yet fail)
shoulda put heslo's car out there instead..........he pulls the chicks lol
Non airbag wheel fail
Turbo cooking engine covers fail
Lic plate in front of indicator fail
Defect waiting to happen.
Yeah, Luke's car doesn't scream "look at me, defect me"
Edited by RubyRS4
hurry up and post some pics then.
gonna get some tomorra, but just so i can say i told you so, needs MOAR offset. will change rims to sumthin nasty when cash allows.
i would have your ex 32 gtr over a chaser any day of the week!!!!! that thing was mint
whats your excuse!?
yeh that gtr was f**king clean, but mehhh, i needed a more practical car, didnt want cop attention, and it started to get a few km's on it and there was a good few thousand that needed to be spent to keep it sweet. i used that as a chance to move on, try sumthin diff :laugh:
Sold your GTR rhys?
yeh mate, bout a month ago. made a bit of cash on her with an offer i couldnt say no on, will definatly be buying another down the line, great cars!
would there be anything wrong with running a series 1 r33 turbo on a series 2 motor ?
lol Mitch it will be fine mate.....as my sig said making 211 from a stock s1 turbs brew
hey hey luke! your in a for a chance now :laugh: .............hopefully that means krishy will leave me alone :P
leave you alone....i mean come on how would that be possible lol
you love all the attention Cara......:P:P:P:P
yeh that gtr was f**king clean, but mehhh, i needed a more practical car, didnt want cop attention, and it started to get a few km's on it and there was a good few thousand that needed to be spent to keep it sweet. i used that as a chance to move on, try sumthin diff :P
a few thousand is a small price to pay on automotive perfection :laugh:
jz tis pretty cool though ill give ya that
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
