Well, I looked, I rang, I browsed ...
There are no type M bars available in South Australia ... privately, wrecking or imported. Fail :P
edit - JIS have one three advertised on their site for $350.
unless its sold... i thought they are usually pretty good with keeping their site up to date with stock
JIS have one advertised on their site for $350.
Depends on how much Paul hassles Koji to update stuff.
yeah, thats what gave me the idea chad. Plus my chances of finding a stock driver seat in the same trim pattern for the same price as a pair of coupe seats + a bit of metal and time for the fab work, its goin to be reasonably comfy too
Anyone know the rough costs of having a worn gear changed in a manual gearbox?
I haven't done a gearbox in years ... and couldn't be bothered doing it myself anyway :P
ruby this is a breakdown of getting my gearbox rebuilt
synchro ring sets-1,2,3,4
input shaft
3/4 synchro hub
synchro keys, spring and sleeves
input shaft bearing
input seal
3rd gear
plus labour in/out plus gearbox oil
total with gst $3,500
got my coilpacks! yay.
That is bad timing - just today I bit the bullet and decided I will sell all the R34 gear I had accumulated, but not yet fitted to my 34. Including a set of Super Spark coilpacks with 3 spares.
Ah ha! Missed them. Cheers, I'm browsing their site now. Will call tomorrow and pick up. :)
These be suitable for 33 series 2 Andrew ?
Edit: Hey Ruby, pretty sure they have 1 series 1 and three series 2 front facia's in stock. One of the series 2's has the factory lower lip on it too.
Edited by Jamesrb25
I've seen that one at JIS - been there for ages.
Tossing up between these 3 that I can see online:
I like this. Complete and just in need of paint.
I can throw this one on without paint for now, being white.
I like the look of the grey S2 with the lip ... but no lights, and will it fit the S1 model?
Dumb Q: is type M and spec M the same thing?
Its meant to be Type M... Spec M is something relating to one of the R34 models.
Thought so ... the two, one labeled "type m" and the other "spec m" looked identical :)
I'd wanna see the bumpers before deciding. I'm also keen on some Work mesh dish rims. :D
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
