Well, I looked, I rang, I browsed ...
There are no type M bars available in South Australia ... privately, wrecking or imported. Fail :P
edit - JIS have one three advertised on their site for $350.
unless its sold... i thought they are usually pretty good with keeping their site up to date with stock
JIS have one advertised on their site for $350.
Depends on how much Paul hassles Koji to update stuff.
yeah, thats what gave me the idea chad. Plus my chances of finding a stock driver seat in the same trim pattern for the same price as a pair of coupe seats + a bit of metal and time for the fab work, its goin to be reasonably comfy too
Anyone know the rough costs of having a worn gear changed in a manual gearbox?
I haven't done a gearbox in years ... and couldn't be bothered doing it myself anyway :P
ruby this is a breakdown of getting my gearbox rebuilt
synchro ring sets-1,2,3,4
input shaft
3/4 synchro hub
synchro keys, spring and sleeves
input shaft bearing
input seal
3rd gear
plus labour in/out plus gearbox oil
total with gst $3,500
got my coilpacks! yay.
That is bad timing - just today I bit the bullet and decided I will sell all the R34 gear I had accumulated, but not yet fitted to my 34. Including a set of Super Spark coilpacks with 3 spares.
Ah ha! Missed them. Cheers, I'm browsing their site now. Will call tomorrow and pick up. :)
These be suitable for 33 series 2 Andrew ?
Edit: Hey Ruby, pretty sure they have 1 series 1 and three series 2 front facia's in stock. One of the series 2's has the factory lower lip on it too.
Edited by Jamesrb25
I've seen that one at JIS - been there for ages.
Tossing up between these 3 that I can see online:
I like this. Complete and just in need of paint.
I can throw this one on without paint for now, being white.
I like the look of the grey S2 with the lip ... but no lights, and will it fit the S1 model?
Dumb Q: is type M and spec M the same thing?
Its meant to be Type M... Spec M is something relating to one of the R34 models.
Thought so ... the two, one labeled "type m" and the other "spec m" looked identical :)
I'd wanna see the bumpers before deciding. I'm also keen on some Work mesh dish rims. :D
