umm this is gonna be probably sound dumb for u turbo peoples
but if i get a stock r33 turbo, will i have to get a stock r33 bov to go with it or can i get a r34 one if i cant find a stock r33 bov?
Lol cara the Blow off valve its self has nothing to do with the type of turbo you are running so Just use a R34 BOV or whatever you can get your hands on, Maybe get an aftermarket one that lets it go to the atmosphere so you dont have to worry about modding your air intake to suit the plumb back factory style.
block it and make it sound like you got 100 pigeons stuffed under your bonnet....btw cara may i ask why you getting a R33 turbo and not something bigger as my stock turbo makes 211 and then sort of runs out of puff towards the end...and no point turbo charging a NA, only to be limited by the turbo......get something bigger for around 300+rwkw mark.....well thats at least what i would have thought :laugh:
ummm... because she is turbo charging an NA??
i'm presuming you dont know much about compresion ratios?? turbo car has a compresion ratio of about 8.5:1, NA is about 14:1, meaning that you cant actually put a massive turbo and/or run much boost on an NA car... its all to do with things exploding =P
Cara, if you haven't done so already, keep in mind the Neo motors have a longer throttle body, so the intake piping to which the BOV is attached to is shorter than your average 33. Therefore the 33 intake piping wil not suit your Neo. Need a Neo DET pipe.
:laugh:
I know its different compression ratios etc......i would really think that it would be worthwhile just getting a DET motor instead of tweaking the NA DE.....and try flogging the DE motor off or use it for spare parts :laugh:
very nice 32 buddy boy^^^.....same BBS wheels as my old bus
you have the coolest job ever Pete
not really Carl.......probably would be if I could charge 1 Gazillion Dollars per year!
LOL Fishy, I think you're thinking of Matty's & my diesel trucks (although they're alot higher than that)....but yeah, comp ratios are higher on NA no doubt.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
